Crankme69
Tookie keep us posted on what ya find in there...I'm very interested
Probably weighed about as much as one of the 6.5 heads![]()
The engine really wasn't even that heavy. Probably 2-300 lbs max, between 2 guys(I'm 6' ~285 lbs and my friend is 6'4" and ~360) it wasn't that much of a workout. I figured it'd be much heavier actually.
No wonder why you like diesels!:thumbsup:
Wussy's,i carry that block by myself:smile5: and i'm only 185 lbsThe engine really wasn't even that heavy. Probably 2-300 lbs max, between 2 guys(I'm 6' ~285 lbs and my friend is 6'4" and ~360) it wasn't that much of a workout. I figured it'd be much heavier actually.
Well on the bright side parts will be cheap:smile5:
While you have it out you ought to freshen it. Rings bearings oil pump etc
Hey, which one of the guys is you in the pic?
Tookie, did you notice a drop in oil pressure with all the diesel in the oil? Esp. at idle?
I'm guessing (hoping, actually) that's not you in your Avatar![]()
