Tookie
Sounded good from here
Yeah, the sound didn't really come across, very
noticeable in person :sad:
I haven't read all 8 pages, so maybe I'm way late to the party. Have you replaced or had your injectors checked?
Update: still got the sound, like a light metal on metal "ting".
Doesn't do it cold, doesn't always do it hot, kind of intermittent.
Got the stethoscope out, checked everywhere I could get to.
Sound (appears) to be coming from the turbo, on the exhaust
side..... nowhere else is the sound as pronounced.
Plan now is to warm it until sound starts, remove the filter
elbow so I can access the turbo, shut it down, have my son
hold the impeller with a wrench to prevent it from spinning,
and listen - if sound is gone, turbo will be too :smile5:
If sound is still present, back to square one....
Had to use the wife's Tahoe to tow the Jeep and trailer this
weekend, cause the noise on the truck has me spooked.
This has to get found and fixed, or I gotta trade up.
No point in having a truck if I don't trust it to go on a trip.
This sounds like my engine--A ting ting ting from the turbo area. I believe missy goodwench mentioned something about it being a common noise in some of these engines
This sounds like my engine--A ting ting ting from the turbo area. I believe missy goodwench mentioned something about it being a common noise in some of these engines, If you dwell on it ,it will drive you nuts. I would notice it when I would drive to a outside bank teller. The noise would amplify off the wall of the building. I've lived with it for years. The only way some one else might hear it is if I bring it to their attention and they "tune in". It has caused no harm, nor gotten worse. It is a very faint sound and intermittent as well---
Every now and again you have to remind yourself it is a diesel.
i had a loose turbo clamp and it literally sounded like the truck was going to explode when i accerlated. tightened it up and it went away.
Was it a really scratchy sound? I had a horrible noise at idle, worse in gear at idle, and gone at high idle. I tightened the turbo clamp a few turns, and it was there, but then went away. (maybe things vibrated themselves sealed again with the new tightnesS?) don't know, but my Harmonic Balancer has a wobble to it and i'm paranoid so I'm replacing that tomorrow.
