Matt Bachand
Depends on the 6.5
Are you sure oil was full of diesel?
What type of smoke was/is coming out the pipe?
I'm tempted to just pull the engine, probably be easier
than pulling the drivers side head in the frame. :mad2:
Probably a good idea, you'd just be mad at yourself after pulling the drivers side head. #6 & #8 are on the pass. side:smile5:
Did the cylinders hold the compression?
What recent work was done? Anything with the IP?
Thats alot of miles on an injector pump too. Is there anyway the pump itself can breach the oil/fuel seals internally causing excess fuel in oil?
400 - 425# on all except 6 (175#) & 8 (300#)
This is getting ugly
Heads gotta come off, best case scenario is a head gasket....
but I doubt it.
Make me an offer, I might bite.... before I pull the head off
Don't know about that, but I think with 175 PSI on one
cylinder, there's not much doubt about how the fuel got in.
It would take a very long time for one injectors worth of fuel to overfill your crankcase I would think.
Do you still have your heatshield in between the turbo and cylinders 6 & 8?
Hoist; You only have one back, and it has to last a lifetime.
we carried a complete Honda 1.6 engine across the street to the car it was to go in.
