Monarkman
Professional Lurker
I'll have one of each, may do some comparing.
Good point I forgot to mention. I will supply the correct connector making it a direct plug in. BUT, I have a dumb question: Will the orinintation of the plug matter? in other words is one wire hot and one ground? I can go put a test light on my truck to find out, but if someone knows the answer I'll go with that.
The connector is the same one I use on my Metrum Rod FSU
Finally came out! Been waiting along time for this! I hope someone gets one has a fuel pressure gauge!
Makes me wonder if its nothing more than larger ports and stiffer spring. Perhaps they modifiied the pump piece inside a bit?
Would be great leroy to take one apart and take a FRB-5 apart and compare.
Take lots of pics!
Should not matter for hookup pump is impulse driven diaphragm/plunger IIRC vs rotary vane.More than likely like any other DC motor it will run in reverse if you hook the power up backwards.
I got mine Monday
