Slim Shady
DEATH BEFORE DISHONOR
- Messages
- 1,523
- Reaction score
- 32
Got mine yesterday.
Hey Leroy are these going inline with the lift pump or replacements? Any mounting hardware needed? May have to get one of those bad boys when you get some, I will watch this tread. By the way wheels are loaded!
Got mine today! Don't have a failed pump yet so going to wait for some warmer weather to change it out and try to get a prefilter set up as well. Every where I check the Wix 24770 with 1-14 filter threads and 1/2" npt is on b/o. Hopefully they get some soon.
So the napa 4770 is the wix base? 1-14 thread, 1/2" fittings. then I go 10 micron filter.
I put this before the pump correct? Then I can eliminate the sock in the tank if and when I need to in the future, correct?
Yes.
Remove the sock when you install my Metrum Rod...
That looks really nice. Be sure to get some pic's of the install too.
(Just thought about this), the pump is flow on fail, so do you need the ball valve?
I went with the stock location. I took a piece of threaded rod (10-24 or 1/4) and made a ubolt. I put in two 1/2" rod couplings as spacers to hold the pump above the stock lines. Snugged it all down on some washers. I will try to take pictures, but it is a crazy day/week. Probably $8 in parts at home depot to use stock location. All in the hardware aisle.
I sucked on the outlet hose until I got fuel into the pump, then hooked it up (to prime it a little, though not necessary). I then cracked the bleed valve on the filter and ran the pump. Picked it right up. Truck fired right up.
I will drive her tomorrow.
