Paveltolz
Доверяй, но проверяй
Actually, I've had good luck.So Paul, you're the one who had the bad ssd air filter on google searches?
You have had bad luck for a long time.![]()
I had 'a' bad filter but the fact, and luck is, that the lid didn't get caught up in the impellers, just sealed the intake like a mason jar...then fall off when I'd work on something only to get bumped around and seal up again. It went on like that for a month. Some other poor chap chunked his turbo and had the real issues with the results and trying to get SSD to own up. In my case, I bought the truck with that thing on there and Walt still replaced the filter with an "improved" model and no hassle.
Same with injectors. Yeah, I made mistakes in purchases but was able to get things corrected before holing a piston so that's good.
New Motor. We caught the problems and corrected them before assembly so thats good too. Now its in, its running strong, and Bill is still actively engaged in dialing things in. As for the injectors in this thing now, they are Bosch HO's that Bill sent out to his prefered shop to have reset and balanced at 2400. That ran up the price a bit more but, I can get 21mpg if I drive at 65mph or 14+mpg if I want to try a few speed runs at 100+mph...and I do...trust me.
3bals, you've got the right attitude as to chalking it up to learning. Let us know how it all goes. Maybe someone else will benifit from the joint learning experiences.
