The fact that he is going to put your faulty injectors back into stock is enough to make me not want to buy from him.
X2 WTF?
At least you get the money back!!!
That is why a set of those sits on a shelf in the barn, never to be installed or sold to anyone. I learned my lesson from here and got a set of bosch remans instead. Yet Walt will resell them and probably sleeps well having no conseince.
What does Kennedy spec their high pops at?
That kind of pop pressure would be pushing the rotor head right to the point of seizing at full fueling and 3,000+ RPM's. Not to mention it would retard your injection timing back a GOOD amount. The 2200 pop pressure is supposed to maintain in the 8,000-8,600 PSI range at the rotor head in the upper RPM's and higher fueling IIRC. So going to 3300 could easily push you past the recommended max range of roughly 11,000 PSI at the rotor head(and I believe it is just shy of 13,000 PSI that the rotor head will shear off or seize). These are DS pump specs if I remember them correctly(been quite awhile since I was up to speed on 6.5 stuff), but I don't think the DB pumps were much if any higher.He recommended 3300, thats what he runs in his built up trucks. He has a mechanically injected 6.5 with a pedestal center mount turbo, over 300hp to the wheels, and he runs 3300 on that truck. Nothing is set in stone, and I am still trying to learn about which psi is right for me.
