Something I am just starting to wrap my brain around (and not sure if this is entirely true) is the relationship of voltage to wire speed/amps when setting up the welder. From what I understand voltage flattens out the bead, wire speed (amps) increases penetration. Obviously you need to have the correct ratio for them to operate properly.A little more heat would go a long ways.
To be honest I haven't event attempted to lay a bead yet as all I planned to do was tack. This welder came with a cheat sheet, but I can't correlate the voltage knob to their recommended setting. Recommended for 1mm is 14.5v, however my range is -5 to 5 volts. Im guessing this is a smart welder, and the volts is based on wire feed. But it gives you a range to alter their pre programmed wire speed. Again, the manual doesn't state this so I am guessing.Right impression of what it does to the bead you see.
Wrong on amps and wire speed relation.
When you crank up the power (best is to forget if it is voltage, amp, etc at first)- the more power you set the welder to: the more it will melt the metal. Both the two metals you are trying to melt together, and the wire you are adding in.
When you have proper melting of the two metals (holding the power to them) if you stay in the same spot on that thin of metal, it will melt away in a couple seconds.
With the wire, the easiest way I taught people was add as much as it will take. Turn it up until the wire hits the metal and actually pushes your hand away and sticks to the metal as a piece of wire.
Do not try to get your settings by ON OFF ON OFF ON OFF tacking.
Take a scrap of the metal and run a bead. Turn up the heat until it is melting out on you like a lightning bolt blast. Then turn it down until you can control it.
Then set your wire speed according to that power level.
There usually is a cheat sheet that comes with welders to say what power level according to the metal thickness you are welding. If yours isn’t- you can search google and just click images and find something similar, but how efficient the welder is changes the settings a bit.
Once you have the welder set to weld properly, it will tack properly by holding still and hitting the trigger for just under one second.
I actually am using a Jackson with the large vision port. It was free, maybe the batteries are getting weak?For vision I always used a big lensed Jackson helmet.
I most generally had a 300 watt bulb going in spots where I really needed to see. I most generally used a #9 lense
LOL. My Jackson's never had no stinking batteries.I actually am using a Jackson with the large vision port. It was free, maybe the batteries are getting weak?
Might have to, wondering if there just isn't enough 'oomf on a 110v welder for a tack penetration on 16ga. I have great penetration on 22ga. When I run beads on the 16ga, sending the beans it makes heat! #s are amps corresponding to the bead on flat material.Try grinding the two edges to make a slight V shape when butted up together. maybe penetration will work better along with filling in the V shape solid.
