dbrannon79
I'm getting there!
Those football helmets are collectors items now. seems like I recall seeing one on a pawn shop tv series where they paid some good $$ for one.
It's does have tig scratch start capability. Would need the gun, and associated tanks to do it. Guessing that would be more than my initial cost of the welder haha!I don't have but very little experience welding but does that welder you have, have the ability to tig anything? I was just watching a YouTube channel yesterday (binge watching Vice Grip Garage for the last week or so) they were LS swapping an old square body crew cab, some 4 part series that was over 3 hours combined. plan to watch the 4th part tonight LOL. showed a short portion on learning how to tig on a little 110v scratch start tig machine. you can weld the tiniest detailed things with those and is almost as simple as soldering seemed like.
Hmmm, I thought all tig needed gas too?Maybe I missed something on the video but I don't think they used any gas. the machine basically heated the metal up to toe point it puddled and he used a coated rod for filler. it almost looked like he was braising but with electricity instead of gas!
Maybe I'm confused? Check out post 190, it's a pic of the front of the unit (robbed off the webs, because I didn't have the unit in front of me that night.)So how about a pic of the welder controls.
All good!Ok sorry, i missed that somehow.
So you are controlling voltage for the heat.
Wire speed is just how fast it add the wire- doesn’t have anything to do with electrical power on most machines- yours says it does, but honestly just ignore that. Amps is honestly how big the load is- the metal corrosion and chemical make up is really what controls the AMPERAGE DRAW. Look at any electric motor and it will say it uses “X” amount of amps. Amps is like how much something weighs when you lift it- the item getting the work done is what determines the amperage.
So with mig (wire feed) welding- just think:
Voltage is the amount of pressure(heat) you are cooking the metal with.
The other control is wire speed: you need to add metal back in as you melt away metal, and if you add too much it will push through the molten puddle and stick to the metal.
Your 110 is too much. The 100 seems in the proper range by what I see. You just need to practice steady controlled movement. I wish you could have someone record your welding zoomed in on the puddle- I (and several other here) could watch it and see what you could do to improve.
Are you pushing or pulling, and what pattern are you doing?
Don’t be afraid to put some work lights around what you’re welding. A common practice is guys adding headlamp work light to their helmet. You have to see the puddle clear, and running dual shield wire, it does not put out as much visible light as regular welding.
I actually did watch this a while back. To be honest I think even before I got the welder! Lots of good info there.
