Ed HD
Formerly: Dad's 05 LLY
The worst part of the fan shroud is that you can't get in at a good angle to get at the fasteners that hold the top half on. They're the push-pin style and they're just a bitch.
Yep, it DOES freak you out to see just how much teh temp swings on these engines. My gauge isn't dumb, and that sucker moves all over the place towing. I can be cruising running 70 and be at 205 or so, slow down to 60 and go up to 215, then drop back to 200. Hit a grade, and QUICKLY spike up over 230 to almost 240 before the fan clutch even thinks of engaging, then RAPIDLY drop back to 195-200 just to have it go back to 215 and stay there for the next 3 hours of flat towing.I'd go in the backside with a strong hose with a tight jet-spray nozzle (or better yet, the nozzle I posted in Mike's thread, the Radiator Genie) and rinse as much junk out from the backside as you can.
And like Ferm said, the factory gauge at 210 basically means it's operating at "normal" temp. If it fluctuated all over it'd freak people out, so they make it say 210 for quite a wide range of temps.
