tanman_2006
Just a farm kid...
If you want a water pump on hand get the high dollar ac delco one that comes in its housing, it's a little quicker to swap. By quicker I mean under 8hrs lol
Pull the inner shroud.... PERIOD
Thermostat set isn't a bad idea, I've seen 4 sets fail over 200k miles.
My u joint were original at 250k, only changed them because I was getting nervous. I'd guess the 6 speed could be rougher on u joints but I wasn't easy on mine at all.
Front hubs fail, 2wd or 4wd has very little bearing on that. If you get the high dollar ones then maybe keep a spare parts store brand one.
Fuel filter is a must behind the seat of all diesels IMO.
I unplug my wif and run a cat set up, the warning comes on in the rain and below 40*.
Fuses, mine liked to blow trailer fuses under the hood and the 12v aux outlet fuse.
Spare tires are handy
I also usually have coffee and beef jerky while on the road too.
