Snot Rocket
it still comes down to how much pressure it takes to open the wastegate, those boost controllers only controll how much pressure gets to the waste gate so really the only thing you can do with those boost controllers is raise boost, because limiting the pressure to the wastegate would make it stay closed , i think someone should see if the turbomaster will work on this turbo
That is why I said you need a can (actuator) with a 8 lb spring. So you can raise it up from 8 lbs.
What the MBC does is hold the waste gate shut until it has enough pressure to move the ball bearing in the MBC. When it moves the ball bearing pressure then flows threw the MBC to the actuator and opens the waste gate. I have made a few of these and they work like a charm.
