Chevy3500
what do you do with the old vaccum lines and vaccum selonide that was connected to the old turbo do you just unhook the lines and remove them or remove the vaccum pump. Thanks I love this site !
I am corn fused :???: Do you mean this turbo does not have enough waste gate area?About 1000 miles on it to report. Still very pleased with the conversion!The one nit pick is that I would like to be able to lower the max boost a little bit more, but have run out of adjustment on the stock/provided rod. The Isspro gauge maxs at 15 PSI and so I throttle limit it to stay in that range. I might just get a higher limit boost gauge. FWIW very very rarely do I get on it hard anyway, but now I am limited still to half throttle. This turbo would be deadly if I could get a full WOT on it!
What Leo saidOK, I'll bite, how do you get multiple quotes into one post??
To the right of the "Reply With Quote" at the bottom of a post is an icon. Click it on all the posts you want to include then click the reply with quote on one of them.
What Leo said
That is cool, Ive been doing it the hard way. Learned something new today and its only 8:00am!!
I just figured it out in the last week or two.![]()
Ah ha! Like this! Thanks a lot. See, old dogs CAN be taught new tricks :hihi:! Thanks a bunch, NVW!
I think its a to stiff a spring in the can issue. You really cant adjust it with the rod length. Those are set at 20 psi IIRC.The wastegate is fine... I just cannot lengthen the stock rod long enough to get the wastegate dump PSI down any further.
These waste gates are actuated by boost not vacuum. Im not following your manual boost controller, care to elaborate?
