ak diesel driver
6.5 driver
I set it. The purpose of the reset was to try and determine if I had a sheared key on timing chain and gear. if it was sheared it would keep moving and I wouldn't be able to set TDCO again without moving IP.
Interesting change in my truck in the last few weeks. About 3-4 weeksa ago it suddenly started much better. Been using a quart of 30 in each tank all summer I don't know if that partially healed it or if it's the "Christine" effect. At this rate I'm going to put it off as long as possible. I've probably put close to 10k miles on it since it started acting up. Mileage is about the best it's ever been too.
I use stanadyne in the winter when it gets real cold.
