ak diesel driver
6.5 driver
It's never smoked like this in the past 7 years. It only smokes until all cylinders are firing correctly. Almost like a switch is flipped.
So you think it should get hot in 5 secs not 10? If so what would you look for? I'm going to replace the controller/relay tonight. Also it does start better with the new duraterms.
If it's getting 12 ( may actually be 11+ volts while under load) volts to the plug and it takes more than 5 sec. to full glow, the plugs are bad. With new glow plugs it's unlikely
Check your connections at the glow plugs
Leo
You might need to explain better whats actually going on, what you hear, feel, and see, because sounds like youre now saying its missing? How long does it do that?
Make sure you try jumpering ECT harness with a 300 ohm resistor, which would stop the cold advance.
Goes without saying perhaps, but I'll say it anyhow. Clean/re-install all your battery terminals, do the batt bolt mod if still using factory side posts, cut the round insulation off the terminals, and check the crossover cable for coorosion.
Make sure both batteries are good.
Glowplugs ground themselves to the block I would think? If not clean the ground that the controller uses? Also as mentioned make sure each clip that the glow's connect too are good, clean and tight.
I get NO smoke whatsover after 2 seconds starting at 40+. No GL-Chip, No fancy override systems.
That is something I'm working on but I don't think it's related cause I ran it for a month after the chip and then it suddenly started acting up.Since you recently put in the GL4 PCM, did you reset the TDCO?
Why not swap the old chip/ecm back in.That is something I'm working on but I don't think it's related cause I ran it for a month after the chip and then it suddenly started acting up.
That sounds exactly like the computer is using its stored values and after 50 starts tries to do its own relearn and without proper timing everythings off key??
It doesnt relearn TDCO every 50th, thats the PMD fuel calibration resistor in OBD1.
Well at least I dont know that OBD2 does that. Thats why you have to do the KOKO procedure.
Need to find a scanner, ask Bison about this one![]()
You could have a glitch in that new chip causing problems.
did.nt you have a similair hard start/no pedal control as i had on my 98 a couple months ago?
a timeset and TDCO relearn solved that for me
Maybe it's the pics, but 1st pic looks like the best glow.
