Husker6.5
Man, there's gotta be a country song out of this saga somewhere!  Or, how about the ultimate in high speed low friction horsepower and fuel economy - a piston-less diesel
If it IS a country song, fire up the turntable and play it backward...
... you'll get your girl back, you'll get your job back, you'll get your dog back, Ted might get his engine back...![]()
I am confused I thought u could not rebuild our engines because the block would have cracks in it so u have to get a new engine?
Chemical Clean Block Caustic soda / hot tank deep clean
Bore Cyl Block .010 .0027 Clearance With Torque minimal overbore a good thing in a 6.5, .0027 piston to wall clearance with a torque plate hone job perhaps?
Install Main Studs, True Linebore different fasteners displace metal in a different way line bore gets all journals straight again
Surface Block .010 removing material from the deck of the block where the heads bolt on, nice and flat again
Install Pin Bushings, Fit Pins, .0004 Clear, Check Alignment pin bushings in small end of rod
Assemble Pistons On Rods don't get em upside down!
Hone Block cyl bores and crank (line) bore, sometimes cam (rare)
True Big End Of Rods resize where the rod bearing halves clamp into brings them to a perfect circle again
Balance Crank Assembly, Stock Balancer Fluidamprs are not used to balance the assy.
Install Cam Bearing, Fit Cam
SH1366S Cam Bearings part #
Specifications:
Rod Rotating-714gr
Rod Reciprocating-332
Rod Bearings-57gr
Oil Allowance-6gr
Pistons, Pin, And Rings-1295gr
Locks-4gr
Bobweight Total-3179gr
Piston Assembly And Rod Reciprocating End Balanced Together
^balancing info- everything must be weighed, even the figure for the OIL that clings onto the parts while running
I'm just happy it is done and the build will begin soon.
a little info, hope it helps
