Husker6.5
A few thoughts.
Note that a decked block changes the relationship of the intake manifold and cylinder head.. Port and bolt alignment.. It can be fixed by another machining operation..(yay... milling of the intake) Same goes for the t-stat xover..
Vic Edlebrock showed back in the '50's that the very slight misalignment of the intake ports due to milling the heads had absolutely no effect on flow. As for any misalignment/interference between manifold bolts and their holes in the intake when bolting on after taking .010 off the heads, again well within the clearance tolerances of the manifold. Take into consideration that you are also using an intake gasket, too.
Machining the intake manifold to compensate for the minimal planing of the heads is merely an act of Type A anal-retentives for bragging rights and the fattening of their machine shop's wallets. Just my humble opinion from many years of helping to build 600+ hp naturally aspirated 327 SBC's for my dad's sprint car team back in the '60's. (BTW, Vic also helped with setting up the custom grind cam specs for the engines we built).
