Husker6.5
Now it's leaking oil at the back of the block, but I think that is the CDR plugging with condensation.
It can also be from the intake manifold bolts not being correctly torqued. Had that problem on my '94 when an "experienced" diesel shop replaced my bad PMD back in '03 shortly after I got the truck. Shortly after they worked on it, I started noticing oil dripping off the back of the block/rear of the oil pan, my oil usage went to hell in a hand basket - so I figured the rear main seal was leaking - and it just didn't seem to have the boost and get-up-and-go it had prior to being "fixed". It wasn't until I tore the top end down after cracking both heads a couple of years later that I discovered that the "professional diesel shop" that had replaced the PMD had not only reused the intake gaskets, but most of the intake bolts were only past finger tight. All the oil running down the back of the block was coming from intake ports 3, 5, 4 and 6 primarily, as CDR blowby being blown out the intake gaskets and down the valley and out the rear of the block - along with most of the boost pressure.
