buddy
Active Member
I also use a 20% methanol mix in the water, so some added fuel.  I dont normally get 24mpg, just long interstate rides with the water meth spray (3.42 gearing).  I havent actually run my propane in over a year, not really needed.
ak diesel driver said:Paul IIRC the pistons have full floating wrist pins which mean that they will rotate in the piston and uses circlips to keep them in place. without the circlips the wrist pins should be able to slide out. Is this what you're refering to with the wrist pins "falling out"?
Mahle pistons are on back order with no projected date for delivery...
Machinist will have back surgery soon...
Todd will not be able to do the engine build...
Changing my first name to Ted...
Other Ted says he will let me have his copies of MaxxTorque with article detailing the original engine build...
Think I'll pass the time making an annex to the article comprised of photos and the dialogue from the two threads and send them to Jamie for the heck of it!
