Electric Fan clutch
WOW didn't realize I had done this 3 years ago. Anyways I checked the fan speed vs pulley speed this evening. As far I can tell they are the same speed. At idle pulley was reading 870ish fan 480ish. With it engaged the fan was the same as pulley. Had my boy try to hold a steady 2k rpm and checked it then, pulley was 2370ish and fan was 2370 ish. Wish there was a better way to hold engine speed steady. Plus if your hand wiggles a little bit readings bounce around some too. There you go Will even after 3 years it's still the same pulley speed.
Use your tech2, under special functions you can adjust the idle rpm's just for testing purposes.
If I could run one of these(I don't have the room, I've checked), I would do either of 2 things. Try and write a program for an arduino to control it as it could read the fan speed sensor for better control. Or I would use one of the new pwm fan controllers. They start coming on about 10 degrees before the set temp at a 60% duty cycle and ramp it up as it gets closer to the set temp. This would change it from an all or none to more of a variable control like the evc was designed to use.
And I would put the temp sensor in the block off plate on the rear passenger cylinder head so it is reading the hottest point in the system, but it would keep the sensor itself away from the heat.
Well, since I discovered this thread about 1 1/2 years ago, I finally completed my switchover to an EV clutch about four months ago and I do have to say, I'm extremely impressed with the performance so far. The thermo clutches just did not react fast enough under very heavy loads and an upgraded Mishimoto radiator (replaced failed OEM with Hayes 2886 - which did not kick in until 230F after 90 sec into long hill climbs). Temp climbs with the new radiator and no aux oil cooling was a bad combination for the thermo clutch (case of the new radiator being TOO efficient - keeping oil temps down while sacrificing coolant temps). The addition of a massive oil cooler a month ago along with the EV clutch and Mishimoto radiator appears to be a winning combination. The EV clutch locks in around 30-40 sec after hitting trigger temp and locks hard (noticeably louder than either OEM or Hayes thermo clutches).
For those of you that have done this mod, did you install the controller in the cab or under the hood? And if you do have it under the hood, where exactly did you install it? For simplicity of wiring I’d like to have it under the hood, but I want to make sure it will hold up in that location.
Hello All,
I've collected all of the parts to try this out on my H1. As ak diesel driver undoubtedly knows, here in Maine the colder ambient temperatures delay the onset of the thermo clutch and my temps spike up close to 220 before the fan engages - and with a brand new P400 installed, I don't want to risk another "oopsies". Until I get the body lift and intercooler all sorted out, I need a more aggressive fan. To my knowledge I'll be the first H1 that tries this.
My question was related to wiring, I see ak dd said he used the red and green wires on the clutch, but I'm not sure how they're actually connected. The controller has an orange 12v out and a blue12v out, and I'm guessing that only one of those is needed for the clutch, but then where does that orange wire go on the pin out for the clutch? Red? Green? There are three other wires as well- which seem to be related to reporting fan speed to the ECM (something I don't require). If I was a bettin' man, I'd guess that the red was the 12v+ (orange from the controller) and the green goes to ground but I just wanted to confirm.
Try as I may, I can't seem to find a pinout for the clutch harness.
Thanks in advance!
Hello All,
Thanks in advance!
Hey there, I just installed this setup on my K3500, but have yet to drive the truck. You are correct on your wiring. Fan clutch Red is + and fan clutch Green is ground. Both Orange and Blue on the fan controller are outputs. I used the Orange to go to the Red on the clutch. I used the Blue to go to an indicator light in my cab so I can see when the controller is commanding the fan clutch to engage. The other 3 wires on the fan clutch are unused. Good luck with your install!
Thank you for confirming! I've got a similar plan in mind with an ON-OFF-ON switch in the cab. It'll be Auto(sender controlled), Off (for water fording) and On. The LED on the switch will be fed by the blue wire. I'm going to splice the "Always On" wire into the AC-on wire on the controller. The 12V power from the battery will be fed through a relay controlled by the switch as well. When the OFF is selected, I'm going to have a warning horn sound under the dash (kind of like the sound you hear when you engage the blower on inboard marine engines before you start them). This way the nut on the wheel won't cause the engine to burn up accidentally after crossing the river.
Sounds trick! I did a similar control scenario as you, but without the ‘off’ option. I like the “HEY DUMMY!” alarm idea.
Hey Maugan, when ya do the install, add one wire in your self made harness that you don’t connect yet. Go from the control relay to the switch on the receiver dryer. Just leave it there at first and don’t connect to anything yet. Get the system in and working, then later it is ready for you to swap out the original one for a trinary switch and tie into the relay to have your a/c turn on the fan when it needs it.
But I say do that one afterwards as it’s own 1 day project because you’ll want to have it all adjusted for the engine needs regardless of a/c first. Then to add the switch you have to evac and recharge the refrigerant. Then its just a couple connections for the a/c.
Are you gonna DIY or have MM do it for ya?
Take lots of pics- it will help others along the way.
Yup thats in the cards Will. In fact the "ON" switch position will just be spliced into the AC wire on the controller somehow - without risking turning on the AC :p
For the AC on wire would you just go for the AC Compressor clutch wire (as it states in the controller instructions or off the dryer harness?
NO
That is the point of the trinary switch. It tells the fan when to turn on by when it will help- having it on outside this perimeter is wasted energy. Rather than reposting it all here, read page 29 on this thread, and watch the videos.
NO
Ok ok Ok Uncle Will! I'll get the trinary switch. From your post on that thread I think you're talking about this one on top of the dryer.
I was going to do the wiring for the swap then let my diesel guy up here do the clutch install since we're going to need to find a good spot to put the temp sender on the H1. He was the one who wanted to do it back in 2019 and is more than capable of pulling it off. Truck isn't going back to MM this year at least. Maybe after I semi-destroy it in Moab :)
Yes thats the location for the trinary switch to go, inplace of the binary switch.
As to location for temp sensor to control the fan- the controller is adjustable so you could install it in any coolant port. Near the thermostats is a good option, but you will adjust it to kick in based on temps you read-
I suggest looking at dash gauge, and ecm reading. Many hummer guys and a few pickup guys fall in love with the scangauge2- that ect shown there is what the ecm is seeing.
My personal favorite spot to read the dash gauge from is same from first 6.2 through the p400- passenger side rear head. Even in p400 it should still be the hottest part of the engine. When you add the warning buzzer for “fan off” mode (definitely in my plans as well) I want to add a low coolant and high temp warning (and low oil) that will tie into my buzzer and flashy red light (probably a laser beam pointed at my eye so I can’t miss it- haha)- consider adding those or any other warnings while making yours.
