jrsavoie
Recruit
I've drilled and tapped thinner metal. As long as the threads are fine, they do pretty good.I drilled and tapped my cross over \, has worked fine for 2 years so far
Here are the wire assignments from A (left) to E (right) based on your first photo:
A and B control the fan.
C, D and E is for the speed sensor.
Connector Pins
A. Fan PWM ground
B. Fan hot
C. Low reference
D. Signal (speed) hall effect sensor
E. +5V reference
Thank youThe letters are there (first photo). They are really small lol...
A = Blue = ground (pwm)
B = Red = +12v power
Hey there, I just installed this setup on my K3500, but have yet to drive the truck. You are correct on your wiring. Fan clutch Red is + and fan clutch Green is ground. Both Orange and Blue on the fan controller are outputs. I used the Orange to go to the Red on the clutch. I used the Blue to go to an indicator light in my cab so I can see when the controller is commanding the fan clutch to engage. The other 3 wires on the fan clutch are unused. Good luck with your install!
Pulse width modulation.A bit confused: forgive not understanding the terminology, but what is ground (pwm)? According to this earlier post on page 15 the green wire is ground
lol ya gotta remember I’m blind in one eye and can’t see out of the other.@dbrannon79 you can plainly see the E on the plug right by your thumb in the top photo. The A is seen directly across from the round manufacturing time stamp emblem.
I am, too. Detached retina in my left eye, I have this black spot in the center of my vision, to look directly "at" something I have to be looking slightly off-center at it.lol ya gotta remember I’m blind in one eye and can’t see out of the other.![]()
Yep. I had to go to scopes. The only open sights I can use are front sight, front sight, front sightMy vision has failed. Have to wear glasses to read or drive. Fibocals. Used to be 20/20 and qualified as expert marksman. I can still shoot okay but the sights, or target, is blurry. Depending on which I want most the focus to go to.
I will have to look at mine and see which wires were used. I know only two are used on the clutch connector. one is ground and other power from the controller. I did find out from experience that the wire colors are different between brands of fan clutches. I at first bought an off brand one then later ordered the AC Delco one.First question, could this thread be made into a sticky ?
Next question: the fan controller wire diagram says that if the blue wire is not used to ground it. I run this to a LED light. Is that going to affect the performance of the fan ?
And last question is : My old school way of thinking is, the wires coming off of the fan itself, red I have to the orange output wire of the controller.
The black wire I run to ground ( old school thinking ) I read through this entire thread and at the very end discovered that the blue wire is suppose to be the ground unit, from off the fan clutch. Is that harming anything to have that black wire run to ground ? I will disconnect it and ground the blue wire and then I think that the fan not kicking in issue will be solved.![]()
