And yes, that is correct. The van/hummer turbos do have a unique and different exhaust housing that the accordian up-pipes directly clamp to. It is the GM-7 turbo and don't think it would be too useful after 10-12 psi as the exhaust housing looks very small, possibly smaller then your normal GM-3 or 4. Standard t4 hey? I have a good idea of how your piping and mount is set up, is it one whole pipe/mount assembly that bolts onto the LH and RH exhaust manifold outlets (N/A), comes up and collects into that T4i mounting flange? I just bought a Volvo HX52 turbo with a 16cm2 housing that I wanted to run on my 93 Dodge, but really would like to use that as a center mount turbo on a 6.2 or 6.5 engine that I wanna run in a pulling truck. Looking into buying an 85 Chevy K30 dually...Dana 60 front and 14-bolt rear...4WD and manual.
I don't weld or fabricate metal though...really need to start doing it and learning. I work in Lancaster too as a heavy truck mechanic for Freightliner. You've probably driven by a number of times...right there where RT. 283 and RT. 741 meet.
