Center mount turbo
That's great, all from injectors huh?
Yea, it lost all smoke and it doesn't lunge as bad from a dead stop on full throttle take off. but it gained torque and as a result much more drivability. Goes up hills with much less throttle input and hold lockup in hi gear very nicely on a hill.
Do you guys setup and rebuild your own injectors?
Do you think non marine injectors set at 4000psi will have similar results as the ones used above?
We build our own injectors. I had a set of standard injectors in a 96 truck an it ran smoother an pulled strong up to redline, but didn't have the torque the marine injectors give.
