nmb2
womp, womp womp... womp....womp...
So he was hotshotting? How can you warranty a tranny when someone is admittedly towing more than the truck itself is rated to tow.
No, he was using the truck for its intended use, no one said he was towing more then what the truck was rated for.
He wanted piece of mind over the stock dodge automatic junk, piece mind? obviously not.
WOW.... Great derailure !!!
Yep!
And I'm glad to see the comments STAY. That is the main reason I don't post on the other place anymore.
Took the truck out for a test run. Smoothest shifting it has EVER had. Fast, precise shifts. Seems like it has more power![]()
The side mount is t3. I made my center mount t4. Much larger... for more flow.
Stop by the shop someday ... or come along up to numidia an watch us run at the drag strip ...... this Saturday!
little far of a drive for me but very interested in how the manifold-t4 flange was setup. You mentioned earlier that you won't be able to test other turbo's on this setup, is it because of hood clearance or was there another issue?
If you need a ride let me know! Or if you want to follow me up there you are more than welcome to!
