I removed the downpipe because it looked difficult to get at the manifold studs behind it. Anyway its off. There was a stud broke off where it bolts onto the cat so good time to replace it.
Can anyone comment on the oil sludge buildup in the CDR line? My wastegate solenoid wasn't working right for about two weeks. I was getting low boost. Could that have caused it or is that normal?
Worked on it again tonight. Got the manifold studs out of the head on the passenger side. They all came out with just using PB blaster. No heat.
I couldn't belive it. Thought for sure I would need heat. I have left it connected to the crossover. It doesn't seperate from the head very far but I guess you don't need much room to get the head out & back in. Got most of my veg conversion off. Coolant is drained, upper rad hose & bracket, fan shroud, upper intake is off. Started on the lower intake but have shut it down for the night.
Looks like the drivers side could be fun. Any tips for that side? Thought about taking the inner fender off on that side but I don't know if I should be fooling with the antilock brake thingy & the fuse block. Looks like the steering column is whats going to be in the way.
What about the wiring harnesses that run along the back of the engine? Can I just work around them? Like they may be in the way of getting the back studs out of the heads.
Can I resuse the exhaust manifold studs? The ones I have out so far don't look that bad.
I know the head bolts have to be put in in sequence but does it matter what sequence I take them out? I'm guessing it doesn't.
I thought about getting a engine hoist more for putting them back in. I thought there would be less chance of damaging a gasket.
Sorry for so many questions but I just want to make sure I don't screw up something.
