turbovanman
I has boost, :O)
Keep it coming guys. I can't tell you how much I appriciate your help. No way could I do this without it.
So I don't have to pull the injectors? Glows?? The machine shop can still work on the heads that way? I don't have a injector socket but could probably find one if necessary? How do you take the lines off the IP & injectors? Is it as simple as putting a wrench on & turning?
You will need to remove the injectors and glow plugs to get the heads checked. I would also buy some plastic caps to fit over the injector thread's to keep crud out.
Lines are 3/4 so you'll need a wrench and a crowfoot to get the lines off the IP.
Buy a new return line kit as well. If you buy a complete upper gasket set, you'll get all the necessary gaskets and the injector seals. IF the injectors are old or you have over 100K someone suggested, replace the injectors, cheap insurance.
