simone0414
- Messages
- 112
- Reaction score
- 0
Turfing my truck & spending even more $$$$ on another is most likely not in the cards. I can't really afford to fix what I've got so spending more on another probably ain't gonna happen either. But you think of all kinds of things laying awake at night. Your right every vehicle is noted for something it seems. I have a peice of crap Grand Am with the lovely 3.4l lower intake gasket leaking as well. Pick your poison I guess. My dad thinks I am crazy for even thinking about attempting this. He doesn't understand that I have a mechanic in my back pocket to help me out.
Anyway took rad cap off this morning & no pressure. Went for a drive, put her through her paces pretty good( didn't come on to her too much cause the spare I have on the back ain't much) & she did not blow off. No smoke & she works like a top. I'm letting her cool off now. That's what's bugging me the most I think is that she's running great. If she was bowing smoke or running like crap I could deal with tearing her apart a bit better. But looks can be deciving as well.
Got under the truck to see what fun I'm going to have seperating the manifolds from the exahust. Looks like there is enough room on the drivers side but the passenger side looks like a pretty tight spot. The bolts are very rusty. For me to do it with no heat I know I am going to have to twist & break them off or cut the heads off with mini zip tool or something. Twisting would make it easier on the passenger side but they are not nuts they are the hex head bolts so I'm not sure I can get enough lb's on them & may have to cut them off anyway. If I break or cut the bolts what's left in the maifolds should be able to be heated & taken out right? Even if they have to drilled & retapped that's possible isn't it?
I would love to be able to take turbo,manifold & head out all in one but I think that's too much to expect. Doesn't look like there will be enough room to unbolt everything. The exhaust turbo bolts look to be in much better shape & fairly easy to get at so hopefully I can soak the with something & get them out.
