NVW
What I did was just place the bolts in the holes and use a large screw driver to pry on the bolts, not fancy but it works.
Actual measurement is 46mm inside between the bolt shanks,not center to center.Alright, I'll order a new CTS (Coolant Temperature Sensor). In no hurry now, so I'll ship it slow boat.
I tried making a tool for moving the IP. A flat plus some 3/8" bolts. I placed the bolts in the IP holes with some sealant on the heads and then placed the bar against them to get an idea of where to drill holes. I took a measurement between the centers of the two marks and it came out to 60 mm. I drilled two holes 60mm apart and they did not line up.
Can someone provide an actual measurement of the distance between the centers of those two holes?
Jump the connector for the CTS with a paperclip...this will allow you to do the timeset...
when you say actual timing which one are you referring to? Actual injection pump timing, or the "actual injection timing" in timeset?
if its reading 14 in timeset mode, then you are way too advanced, you have to get that around 3.5, which is more towards passengers side.
If reading 14 when in timeset mode I would venture to bet in the dashboard mode you can see an idle "desired injection timing" of around 8 degrees and "measured injection timing" of 14, becuase you advanced the pump so much it cant get back to 8 anymore. You will read a TDCO of -2.02 until you get it back to under 4 degrees actual injection timing in timeset mode.
actual injection pump timing will read around 28-30 degrees.
That note in red is actually wrong though, it should never read 3.5/3.5/-0.5
It should read 0/3.5/-0.5 stock in timeset mode.
However at just idle in the window you should see what most stock programs tuned for idle timing which would be about 8.5 degrees desired and actual/measured should be the same. So you would see 8.5/8.5/-0.5
So BigT you are correct. you want to turn the IP to the passenger side until its about 3.5 degrees in timeset mode with a desired of 0 degrees. For performance you can get it closer to 3.8 degrees actual while desired is 0. Which will yield around -1.5 TDCO when you go to learn it. clear the codes with GMTDScanTech is possible before learning TDCO. If you cannot delete DTCs with the scanner, there is a manual procedure using a jumper on the OBD port and the accelerator and brake pedal.
Just to help you visualize it, you are trying to set the timing within a window.
-2.02*...........0...........+2.02*
