NVW
It's on the pass side of the IP, the ECM controls it, it changes the internal timing of the IP by rotating the cam ring. It may be seized. It's hard to see but try to have someone rev the motor and watch it's movement if any.
No prob. You don't seem to be making a connection or something if the timing can't be changed, that or the stepper is seized or just sticky. I'm now leaning to a bad connection or grounds. Even if the stepper were stuck, the learn procedure should work.
One more thought, the timing cover has been off 2x now. Is the CPS connected?
Mebby we need to back up a little bit.
Big -T,what was the problem with the truck before you swapped chains?
What codes did you have that time?
You can see in GMTDScan if your OS and CPS are in agreement. If not you will see crank counts missed or cam countrs missed. And a DTC17,18 or 19 will show up.
turning IP toward passenger side would be my first move.
In GMTDScan you can see cam reference missed, or crank reference missed, you have to select it in the dashboard view. Or it shows up in the snapshots you can take.
So in short would you say that you lined the marks up to be 12 crank, 12 cam, 6 IP?
You lined up the cam and crank then spun it so cam was at 12, and lined up the IP gear with the cam gear. so that would be 12, 12, and 6. Which is correct. And the IP should go in the oval hole of the timing gear.
