ak diesel driver
6.5 driver
Program won't allow tdco set until engine reaches 180 degrees in temperature.
No, the temp has to be 180.
Try moving it a RCH back to the pass side. Time set should only have to be done once after each IP move. Then do a learn, learn can be done several times if you don't get a result you like. Revving the engine can also give different results. If you see what you want stop the learn.
I think it is twice the thickness of a BCHOK in the GMTDScan program under Top Dead Center in the Tools it has Timing Set on the left and TDC Learn on the right. Both have buttons that say "ON". If I click on the button, then a button appears that says "Off". So I have a real basic question: when is it on? Is it on when the "On" button appears? Or is it on when the "Off" button appears?
If it's on when the "On" button appears, then does it only do the the Learn when the temp reaches 180? If that's the case, then I haven't brought it up to that temp. I believe it got just below that.
I really need to get that long wrench bent as it's a real PITA with it straight.
Moving it a RCH to the passenger side? I'm afraid to ask, but what's a RCH?
You don't know nothin, it's 1/2:smile5:
When activated and it highlights off, then it's on and vice versa.
RCH- the first letter is "Red" I'll leave the rest to you
You've obviously never had a true red head
O crap Big T now I am seeing double.
When setting TDCO, you have to be warmed up, 170F is fine, I do it all the time, because mine wont get over 180 at idle. I'm not even sure GMTDScanTech has this requirement, but you should let it warm up so there is no cold advance applied and youre seeing the true timing.
Also, you have to clear the DTC88 prior to performing the learn function. So clear the DTCs, then Learn TDCO.
dont worry about the desired and actual values at idle. That is PCM controlled. For timing it, only look at that in the timing window when you hit Time Set On. That will show you the base cam timing and should be about 3.8 degrees average, and youll be set for about -1.75 TDCO, and if closer to 3.5 degrees average about -0.5 TDCO.
With the IP nuts loose you need a tool to turn the pump still. I took a bar and threaded two holes and put two 3/8 bolts through to make my own IP timing tool. Before that I used an oil filter pliers .
After you move the IP, make sure to perform the time set also. So you'll clear DTCs, perform the time set, then perform TDCO learn.
Both the Time Set and TDCO learn will end themselves after about 20 seconds. Or you can hit the OFF button yourself to stop them. time set needs to be done after you move the IP. You can stop Time Set after about 5 seconds, just so you can get a good idea of the average value. TDCO you can stop it too, whenever you see the value you desire. Heads up though, TDCO doesnt always stick when you hit OFF, and you might just have to try again (just hit TDCO Learn again).
For me if there is a TDCO value higher than I want, like if its right around -1.94, but goes to -2.02 (which will cause DTC88) I can rev up the engine a little and TDCO will come down a little and I hit OFF when I see the value I want. That is backwards for OBD2 trucks, maybe because they increase idle RPM when going into TDCO, but mine goes into TDCO at whatever idle is, like 600RPM. So the real point might be that revving might not help you increase TDCO like it does some others.
Your stepper motor on the IP may not be moving
