Big T
I think the flats on CPS run paralel to the crank shaft
Yes, I concur, but the CPS could be rotated 180 in its hold down bracket. Does that POSITION make a difference?
From the linked thread:
If I take the mechanics word for it that he did not find the injector pump gear out a tooth, I believe the root cause was that he broke the bracket off the crank position sensor and when he reinstalled it he got it aligned 90 or 180 degress out. This results in the timing being out in relation to true TDC, but correct in relation to the crank sensor.
In the thread I linked, I'm experiencing exactly the same thing as the original poster. Can't get it close enough for Time Set or TDCO Learn. Almost the same readings between Desired and Actual and the same inability to bring it into tolerance (for a Time Set and TDCO Learn) by rotating the IP. Then I read that people were suggesting he must be a tooth off on the timing gears (he wasn't) plus all sorts of other suggestions like IP faults, stepper motor gone bad, etc. The final solution was a new CPS and he concluded that he might have been 90 or 180 off on the CPS because the plastic was broken, thus my question. The plastic was not broken on my CPS, but it definitely could be 180 off in the bracket.
I'm going to pull the CPS vs pulling the water pump again.
