Good for you, BigT ... way to be persistent!
I try to stay quiet on things I know bugger-all about, and CPS is one of 'em... Like Leo, I not know a bunch more, thanks to you taking the time to talk everything out and to your posting pictures!
I noticed that you did not jump in and it was frustrating me, but now you've explained why.:thumbsup:
And yes I totally understand that some of this is very hard to advise on when you're not there. Many times I was scratching my head thinking these guys aren't looking at the same thing I am. They're not describing in a language I understand. It was that realization that kept me coming back, explaining, re-setting the thread, etc. I tried really hard not to tear into anyone out of fear that I would lose their input permanently, which probably meant that I would not get my truck back. I put it down, sat on it, went to work, thought about it and re-thought about it. Yesterday I spent most of the day studying threads and searching here for more. Then I found that thread where the guy was describing exactly what I was experience and it was on a freshly rebuilt engine. There was also another thread by Matuva (I need a road trip to New Caledonia) that I studied many times about a month ago as the symptoms were very similar to mine. Finally, I just refused to believe that certain items had gone bad when they were perfectly fine before I started this job and I had not touched them. I did know that I pulled the CPS and the other threads helped me to zero in on this. I am happy that my painful experience did lead to all of us learning something new and simple, but very critical. I guess I need to file this under "just because it fits, doesn't mean you should insert it."
I guess Santa saw that I've been a good boy, as here's the snapshot after Timing Set and TDC Learn:
Snapshot created 12/27/2009 2:15:30 PM
__________________________________________________________________
ENGINE SENSORS
Engine run time: 00:01:51
Boost pressure (MAP): 14.6 PSI
Desired EGR: 15.23 PSI
Desired idle: 562 RPM
EGR pressure: 14.58 PSI
EGR duty cycle: 0 %
Engine coolant temp: 186.4 F°
Engine speed: 562 RPM
Glow plug relay feedback: 0.1 Volts
Glow plug voltage: 0.1 Volts
Ignition voltage: 13.4 Volts
Wastegate duty cycle: 67.2 %
INFORMATION SENSORS
PCM Calibration ID: 6885
Current DTCs: 0
Accel. ped. pos. 1: 0.71 Volts
Accel. ped. pos. 2: 4.29 Volts
Accel. ped. pos. 3: 4.02 Volts
Barometric pressure (BARO): 13.72 PSI
Battery voltage: 13.5 Volts
Fuel temperature: 98.2 F°
Intake air temp: 87.6 F°
Throttle position: 0 %
Turbo boost (Calculated): 0.88 PSI
Voltage reference sensor: 1.3 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 30.89 Deg °
Cam reference missed: 0 Counts
Crank reference missed: 0 Counts
Fuel calibration: 115 Counts
Fuel rate: 9.06 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 9.06 mm³
Fuel rate - Maximum transient: 35.62 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 1.98 ms
Injection timing - Measured: 8.7 Deg °
Injection timing - Desired: 8.6 Deg °
TDC offset: -1.94 Deg °
TRANSMISSION SENSORS
3-2 PWM solenoid duty cycle: 0 %
Cruise target speed: 0 MPH
Cruise speed error: 0 MPH
Current gear of transmission: 1 Gear
Current torque signal pressure: 25 PSI
Current transmission ratio: 1:4 Ratio
Error between desired and actual shift times for latest 1-2 upshift: 0 Sec
Error between desired and actual shift times for latest 2-3 upshift: 0 Sec
Force motor (PCS) - Duty cycle: 43.4 %
Force motor (PCS) - Feedback current: 0.82 Amps
Force motor (PCS) - Reference current: 0.82 Amps
Time of latest 1-2 upshift: 0 Sec
Time of latest 2-3 upshift: 0 Sec
TCC PWM solenoid duty cycle: 0 %
TCC slippage: 10 RPM
Transmission input speed: 548 RPM
Transmission output speed: 0 RPM
Transmission temperature: 153 F°
Turbine speed: 548 RPM
Vehicle speed: 0 MPH
