After making my way all the way across the top, I went back to the end where I started. I used the scraper again to give myself some room to work, then started driving again. At this point, some may notice some damage where the rolled edge has started to roll up. This was what happened during some of the beginning stages. After I figured out that driving straight in seems to do the trick, I didn't have that damage occurring any longer. Again, this is just for practice. This cover is already damaged and I won't be using it anyhow.
After the front end was done, I moved toward the rear to start the same procedure. By the time the ends are done, the only edge left is the one toward the injectors. Notice that by the time I moved back to the rear, I used the technique described above and didn't damage the rolled edge, as seen below.
Then at a slight angle, again, I drove the putty knife perpendicular to the cover, as I did with the top and worked my way along.
One thing to note is that driving the putty knife too far on the upper edge toward the intake, could result in damage to the push rods. I would suggest a paint line on your putty knife or something of the sort to help determine the depth the blade has been driven to prevent getting carried away.
I didn't expect to see this Navistar emblem in the casting. I had it in my mind it was only in the valley.
By no means am I claiming this is the best way, as there are a dozen others on here that have probably had way more success than me on this and have done it with much more finesse. I hadn't seen much of any writeup on it, though, so even if someone criticizes, and offers better suggestions, we'll have some photos to use to point out my errors.
