Twisted Steel Performance
The bearings need to be new to coat, I prefer to coat new parts, to get the oil out of used parts require extra process and cost.
I'm pretty sure I understand the process. I just hadn't heard of pression gauge before, so it wasn't clear to me. I thought it was a typo at first, but then when I found the part with the search term, I didn't see how I could use it for the measurements.Search for a bore gauge... Mics for the od of crank, mains and rods, zero the bore gauge to the mic measurement, use the bore gauge to see how many thousands the difference is.... I could explain it better on the phone...
I noticed, too, that the harmonic balancers are clocked differently in relation to the keyway. Is this something I need to be concerned about or that I need to keep in mind when replacing? Here they are side by side. Notice my attempt at a line from the keyway, through the center, then to the mass on the opposite side:
I've found that it looks like the timing case is the same with the engine using the DS4 and the DB2 (Incidentally, I don't think I mentioned it nor do the earlier photos show this, but the donor HMMWV engine was equipped with mechanical pump for some reason). Inside, though, I found a difference where there is a plate behind the gear on the injection pump. The one with the tool box showing through the opening is my '95 and the other is the donor. What is this plate and do I use it going forward, assuming I continue forward with my factory DS4 setup? I am making the assumption this is either an update or something just for the DB2, but really have no idea. The last photo shows the plate once it is out.
On the oil pump drive - is one design preferred over the other? They're different, as you can see below. Does this matter?
Yes, it will be getting balanced. I studied it for quite a while yesterday before I convinced myself they were different. I drew the line to try to show that. I'll look at it here again in a little bit. I understand what you're saying about them 180 off in the photo.Well the first thing I see is in the pic they are 180 deg off, both are not orientated the same, that makes it look very different to the eye...
Are you going to balance the motor ?? If so take both and if needed the machine will tell the truth...
I have that fill neck from donor motor, too. What does the end result look like with the catch can? I had planned on using factory CDR, but am not locked into it.That's a baffle, I use it, some 6.2's and hummer's have the cdr in a different place and use a different oil fill tube...
reason for my choice - will not pick up oil like the screen in the valve cover does, I use a good catch can, looks better...
See pic...
I have the reluctor on both engines, but didn't take a picture after I took off the balancers.And one other thing about the balancer's, DB2 = long snout , DS4 = short snout and reluctor....
If I use the chain again, am I going to have to plan to replace again in 30,000 miles vs gears? I don't plan to tear this apart again if all goes well. At one point in time I was thinking you mentioned favoring gears.And on the crank gear, why remove it ? The gears aren't what loosens up or ware, the chain is, and chain can be purchased by themself.... unless you are going the gear drive route, if so screw the bolt in the crank and use a puller and a little heat if needed..
