orrum
There u go Nobby I agree completely with u and thanks!
Thanks Jeff maybe I'll try one.
I am almost sorry I started this post, 1st I got smart ass comments back from Big T that helped NO one.
SORRY Big T & anyone else that needs thicker skin!
To be fair Tim, I do want to point out on your Pickup you are running Heath's Balance flow as well. To my knowledge you are the only one running it. As far as 7.3 PS I have owned one and my father owned one and there is no comparison. Ford got it right with that combination. It's near impossible to overhat a Healthy maintained Stroke. Of course if you even have to work on the damn thing, you'll be hating life. Aside from the waterpump, everything on it is a bitch to do and tres expensive. I still think a bigger rad will do alot. I'll know shortly. I just can't get out of my head having owned older versions with the copper rads and never having any issue that it's not a factor. Hey if you didn't sit around scratching your head about turbos, there wouldn't be an ATT right ?? If I fail, then it put's it to rest once and for all but if I'm right alot of guys are gonna be at the junky looking for CUCV rads...
The first appearence of the 6.5TD in 1993 sported a copper brass rad and then GM went to the alum/plastic one in 94...Now put this in your pipe and smoke it for a sec...
GM(or any manuf) doesn't look to make improvements the second year of production right ? Hell they usually don't get it right till the last years (case in point the 99+ WP's) So I'd be hard pressed to believe they went to the plastic rads in 94 as an improvement. Nope I think it was to save money, plain and simple.
I could try a poll to see if 93 owners with copper rads have the same issues as those 94+ but it would be biased anyway as the difference in fuel delivery of the DB2 vs DS4. I own both side by side and the DB2 puts out less fuel and substantially less egts atleast for me anyway.
However I would be curious to know how many rows most people have in thier Alum/plastic rads factory. 2 or 3 ?
I'd venture to guess that would make a big difference. I know it did on several hotrod gasser trucks for me over the years.I do think you are on to something, as that HD doesnt have near the heating issues with the brass radiator, although it doesnt have a condenser, due to it being ordered with a/c delete, surely that helps as well.
No balance flow on the burb Kenny & no overheats, I don't think the BF on my truck is the edge you think it is. When I 1st got the burb it was an over-heater but a DEEP CLEANING of rad & condenser fixed that, also upgrade to spin on retuned fan-clutch & Heath water pump.
My BF on the truck is still there because I have an OE 4 bolt pump on the truck and that was direction Bill went with those before going to current setup due to costs and equally effective result from current setup he sells BF no longer offered as the choice for the 6.5 in our rigs.
My project engine going in will have latest pump from Bil but I won't be putting back on the BF as paired with that pump it is supposed to be counterproductive; so I'll have some comparative data one day.
