Acesneights1
what you are attempting is a balance flow. That was Heaths first solution to cooling. TD has it on his truck except the t'd lines are dumped back into the thermostat housing via installed barb. I just don't remember if it was pre or post thremostat but TD put pics up somewhere .On my Tahoe motor I connected the two rear coolant block off plates ,with a tee and ran that to the heater,which will return into the radiator. I don't know how well it will work,but I've seen lots of v8 gas motors with RR heater outlets. It seems to be the hottest spot
