ak diesel driver
6.5 driver
Should have spoken up we could probably have come up with some alot less rusty for you.
I remember and like that show. But what does Mork from Ork have to do with it?
... Mevotech is the shiznit...
Nah-Nu Nah-Nu!
Ah, that’s the connection. I think Snoop Dogg said ‘shiznit’.That's 'Shazbot' Mork used to say.
Thanks again for the thought. Oh I should point something out: I was able to safely remove the upper ball joint nut without a clamp or vice grips holding it together because I still had the torsion bars loose, if there was full tension on them that could get pretty unsafe without some kind of a safety.That looks so much cleaner of an install, too, @n8in8or without those washer stacks! More befitting of your build quality standards, also!
Yes sir. Everything else was new so might as well do that too, and it didn’t seem right to put just any box on it from what I’ve heard a out other brands.Do I see a red head steering box on there?
Well I’m not doing any custom work so that helps. I’m still weeks behind my 3 weeks schedule though!Nice work!! It amazes me how fast you got that chassis done. How much will you charge me to finish mine![]()
Thanks! I had to look up the order from Amazon. The vendor was The Stop Shop and they claim to be the manufacturer as well? Not sure on that. It did have some ink stamping on it and I noticed DOT, but didn’t noticed a manufacturer....I’ll have to look again.Nice looking bends!! What brand line did you use? NiCopp or SUR&R? I'm bias towards SUR&R because it's made in Ohio.
Thank you!Nice work on the brake lines.
I have a bunch of mirrors left over from a home remodeling project. I'll send them your way so you can lay them under your truck at Cars and Coffee.![]()
