MrMarty51
Looks show quality to Me. of course, You should see some of My welds. LOLOLOLThank you sir! It isn’t show quality, but it’ll do.
Thanks Les!looking good!
I think for my next place I need to get a big building to live and work in that is surrounded by 10 acres of concrete. Then the only maintenance I’m doing is on the building to do my work....none of this house repair and yard work BS. I doubt Kelli would dig that though.I feel your pain. I lost my whole week / weekend to fixing my mower and doing yard work. Gotta get it done why the weather is good.... for once.
Nice job on the knuckles!!
I think Big T kept the gmt400 tie rod ends
That’s what I was remembering, that you did adapters on one and 409 ends on the other one.On the ‘99 I kept the gnt400 ends and used the adapter sleeves, which I purchased from a member here. On the ‘94 I used the 409 ends. Can’t remember the issue. I do remember spending a lot more time reaming.
I still like the 409 ends and they would be my first choice on the next one, just not without modifying the arm to make sure they have full movement.....or maybe getting a thinner nut so you don’t have to ream so deep, but honestly modifying the arms was one of the easiest parts of the whole conversion so I feel that is the way to go and not compromise the nut.
Have you been under the trucks to inspect the suspension and steering since doing the conversions?
Been under the truck many times and no issues. I would go with the 409 ends too. There is an ever so slight bit of play in the machined adapter sleeve on the driver’s side. Too slight to impact alignment, tire wear, or steering feel.
Now that you’re done, what do you think of the brakes?
I'm glad to hear you haven't had any issues.
Oh I'm not that far yet. I put the first coat of paint on the knuckles this morning and the frame is still missing all of it's suspension......oh......and a body..... I'm really looking forward to having a great brake system when I get it back on the road though!!
Yes. Rust Belt Central indeed! My first set was around $30 each including the hub at the pick a part yard. With the current Covid situation and my desire to keep moving as fast as I could I opted for a pair already pulled when I needed to replace them. The second pair (the ones in the pictures) were actually nicer looking than the first pair I had. Yep, the knuckles are the cheapest part for sure. It should be worth it though!Those are some crusty steering knuckles. You’re in Kalamazoo, MI? That is rust belt central.
I can get them for $27 apiece when the pick a part yard has a sale. CA units not crusty. As you’ve learned, the knuckles are the cheapest part of this upgrade.
