n8in8or
Nice choice in buttons. Looks like a squeeze to get them both on that little plate. Some careful drilling there.
I'm guessing that the LED is connected to the same side of the relay as the fan, or fan clutch in this case?
If you push the button while the temp controller is already commanding the fan on, will the fan remain on if the temp controller drops out?
Yeah there wasn’t any room to spare to fit both of those nuts side by side in there (that’s what he said..).
The LED in the switch is running parallel to the fan clutch.
The push button and the temp controller are also running parallel so as long as there is a signal from one the fan will turn on. The fan controller for the fan clutch has all the wiring to do this built-in, but for the trans cooler fan since I’m making my own controller using a relay I’m incorporating diodes in each leg of the circuit so they can’t back-feed.
