ak diesel driver
6.5 driver
Pretty crappy video but you'll get the idea
I wish I had some info to help you out, but this turbo is a CKO Holset and that’s the orientation the actuator was in when I bought it. Sorry.Hey Nate, I know it doesn't exactly pertain to this build, but if not touched on in another thread of yours, would you be willing to explain how you adapted the wastegate actuator arm to the horizontal orientation? I'm trying to configure my 35/40 to fit the same way. The actuator arm is 5" and I'm wondering if I need to get a longer arm so it can still connect to the wastegate. Looks like I need to drill another hole and perhaps cut off some of the actuator bracket, but before hacking it up I'd appreciate some advice from someone who's already done it successfully![]()
I suspect you already know Holset uses a horizontal arm or a right angle arm (centerline of turbo/compressor), depending upon application...in tight situations a non waste-gated turbine housing is used with remote blow off valve.Hey Nate, I know it doesn't exactly pertain to this build, but if not touched on in another thread of yours, would you be willing to explain how you adapted the wastegate actuator arm to the horizontal orientation? I'm trying to configure my 35/40 to fit the same way. The actuator arm is 5" and I'm wondering if I need to get a longer arm so it can still connect to the wastegate. Looks like I need to drill another hole and perhaps cut off some of the actuator bracket, but before hacking it up I'd appreciate some advice from someone who's already done it successfully![]()
Qualifies as under hood ART...I found a boot that fits this connection better. It’s a lawn tractor battery terminal boot.
I had the phoney up to my ear so I could hear the pump run, mighty quiet, read Your comment then hadda play the video again.Wow, that's a lot quieter! Thanks for sending that. And look at all that snow still!
I'm disappointed the breakers don't match. I ordered the first one from Summit as a well-reviewed American Autowire brand breaker. When I received it, it was a bagged kit with this Gloso breaker. I looked up the Gloso breaker and it showed up on Amazon, also with good reviews and for less money. So when I needed a second one I just went to Amazon. This one didn't have the Gloso name on it so now they don't visually match. Not a big deal overall, but definitely a deduction in style points.Qualifies as under hood ART...
Thank you sir. It’s overkill and I know it, but it makes me happy.Your stuff looks like NASA assembled it ready for space! Love it.
I’ve been thinking about a spin on one as well after seeing all the crap this screen caught.No kill like overkill!
Your coolant filter/ screen gets me to thinking I want one. Why you do that!?! Haha
I’ve been thinking the spin on style (without the nitrate tablet of course) but they are big and ya can’t tell when it needs replacement.
Hey Andrew,Hey Nate,
I see we have the same taste in vacuum pumps.![]()
I was going to make the same comment that it looks like it getting mounted to the space shuttle.
Is there a reason that you ran the negative battery cable to the front of the truck rather than going directly to the frame?
Then from the frame to the engine block. I guess it would mostly just save time and material.
Do you have a part number for that turbo blanket?
I like what I see!
