n8in8or
You sir are an animalawesome as always!
Ha, thanks! I did get a steroid shot yesterday for my poison ivy, so there may have been a little roid rage going on.
Yup. It’s gone. I totally rerouted the power distribution when I got rid of the harness going across the firewall.So you totally got rid of the little buss bar/ fuse center?
The harness across my firewall was melted directly over the 6.5, GM should have included thermal sleeves across that entire area...Yup. It’s gone. I totally rerouted the power distribution when I got rid of the harness going across the firewall.
I always hated those things. Not like they failed or gave problems- just looked ugly and seemed like a cheap way out to me. I like your solution better.
You just quit that now. He is helping me live vicariously! Haha. . . And then there's that skid steer. . .![]()
So Nate can you school me on heat shield and header wrap? I'm thinking I probably should wrap my down pipe, I've never done anything with header wrap. Any products that you think are better than others? Any installation tips?
I don’t know that I’m qualified to “school” anyone on this subject, but I’ll be happy to share what I’ve used and what I think of it. Soon.....So Nate can you school me on heat shield and header wrap? I'm thinking I probably should wrap my down pipe, I've never done anything with header wrap. Any products that you think are better than others? Any installation tips?
I’ve been really happy with pretty much anything from Design Engineering (DEI). The first thing I used of theirs was their silicone exhaust paint years ago, when I was just trying to find a high heat paint that would last. It definitely holds up, even on a vehicle daily driven in Michigan winters. I put that on my HX40 downpipe adapter when I made it and it’s still holding up well. Later I discovered that paint is designed to work with their header wrap, so that’s what I used to wrap the header and the crossover pipe. I sprayed it on the pipes as a base coat and then per their instructions as a top coat to seal the wrap. I had to rewrap the crossover pipe because the wrap got damaged while sandblasting the underside of the Hoe.... the pipe was starting to get a little rust on it under the wrap, but certainly it wasn’t rotting out. It wouldn’t be as good as having it coated with a high heat ceramic product since it adds that layer to trap moisture, but it works well for a DIY application. It’s also pretty readily available because you can get it off Amazon, and even Advance Auto Parts and Oreilley stock some of their stuff. I just follow the directions for the wrap and it goes fine.....it just makes my hands sore after a while manipulating it and holding it tight, but oh well. Then secure the loose end with stainless cable ties.So Nate can you school me on heat shield and header wrap? I'm thinking I probably should wrap my down pipe, I've never done anything with header wrap. Any products that you think are better than others? Any installation tips?
Thanks! It feels good to have things working for the most part. I’d love to hear what your newer pump sounds like. To be honest it was definitely louder than I remembered, but I would guess with the new plumbing it should be able to really sing now. Oh and thanks for your old pump - I took it apart to see how they do the regulator and then took mine apart and made a spacer to 100% bypass it....even with the screw turned all the way in it would still allow some to bypass.Woohoo! Sounds good! I'll have to post a video of my new raptor pump. I had to smile when I heard the familiar whine of the older one.
