n8in8or
When I sent the pic of this to my brother, he said he could warranty it through his Snap On guy. I thought he was joking, but he was serious.
He did!iirc Ferm commented on the red heads having issues now. I could be mistaken
??? That price is way off "$695. & is in stock ; https://www.pscmotorsports.com/psc-sg840.htmlnot alot of options out there, I bought a red head recently. The PSC when I checked was unavailable ATM and was over $1200
That is generally that is my problem...Maybe my old-timers is the problem
And mine, too!That is generally that is my problem...
I’m going to cut holes in the sides of the boxes and use sealing washers on the studs.Are you planning on connecting the terminals while in place or before you slide the batteries in place?
My subscription must have ran out.I haven't received a notification to this thread.
Looking good Nate!
I like the battery relocation. Are they easier to get at than the pictures show? I would like to get my batteries out from under the hood as well.
You should sign up for n8in8or Prime so you can be sure to not miss an update.
They shouldn't be bad to get in and out.....to remove, you just slide the battery box back and it will drop out the bottom. Of course since your truck is apparently never going to have a bed on it again it will be much easier for you.
I'll try to take a video at some point to show how it works....probably easier than words and pictures.
