Big T
This is creating a patch of oil everytime I stop and these leaks were not there before I installed the CKO Provent.My 95 leaks from both areas and doesn’t have a proven on it. It’s not much but residue is there. I think you mentioned that you’re using the real provent filter rather than the stainless mesh that came with the cko provent? I would check flow though by blowing by mouth into the side from the valve cover and see if air is moving freely though the filter and provent housing. Does your provent have a check valve in the bottom where the lower hose connects? Mine didn’t but the real provent is supposed to have one.
