Big T
Did you try a screwdriver or jumper wire?
Is the exciter wire, purple?
Are you getting power to the exciter wire?
Do you have a load tester?
Check both batteries?
Check at the end of the cable going to the starter?
Purple to relay has power. If we jump the incoming purple power to the the outgoing purple to the starter, we do not get the starter to run. Need to confirm continuity on the purple wire to the starter.
No load tester. Did check battery voltage and got 12.5 at both.
Reportedly AAA has located a tow for us. Will have it towed to our place and continue the troubleshooting there.
