Jaryd
Extremely Deplorable
I'm having a brain fart what is a SAS suburban
A straight axle front differential w/leaf springs.........I'm having a brain fart what is a SAS suburban
Straight Axle SwapI'm having a brain fart what is a SAS suburban
Rides like an oversized CUCV.How is the ride in a straight axle suburban? I know in pickups it make a big difference, just wonder how it is with the difference in weight.
I've rode in a locals lifted Burb that was converted to SAS rode OK but way too high for me. If I do one it will be at minimum lift to make it work and be what I call a cushy ride not stiff or harsh.How is the ride in a straight axle suburban? I know in pickups it make a big difference, just wonder how it is with the difference in weight.
Wasn't......more a bondo queen than anything else.Hopefully its in good shape.![]()
Bummer.Wasn't......more a bondo queen than anything else.
You've done so much to make your burb the way YOU want it, that I'd have been very surprised if you found another one that would make you happy as a substitute - straight axle or not.Well, the older Burb is a wash lots of bondo covered sheet metal and chassis is rusted almost completely through and covered in some type of undercoating trying to hide the damage....Oh well an SAS on this Burb will become reality soon.....
I wonder what the minimum lift is that you would have to do in order to fit a straight axle under the front? My F350 with Dana 60 is a LOT taller than my Tahoe and the front springs are flat (no arch).I've rode in a locals lifted Burb that was converted to SAS rode OK but way too high for me. If I do one it will be at minimum lift to make it work and be what I call a cushy ride not stiff or harsh.
I have seen 3" using FORD high pinion differential but suspect off road articulation will suffer somewhat.You've done so much to make your burb the way YOU want it, that I'd have been very surprised if you found another one that would make you happy as a substitute - straight axle or not.
Yeah, that sounds about right.I have seen 3" using FORD high pinion differential but suspect off road articulation will suffer somewhat.
While IFS can be fine tuned on lighter vehicles it becomes difficult on the heavier suspension systems IMO, while monster CV axles can be had the cost is almost as much as as a FORD high pinion conversion.Yeah, that sounds about right.
One owned by British Army Special Forces (SAS) troops. Right Hand Drive, so it drives on the wrong side of the road, right @Will L. and @Paveltolz ?!?I'm having a brain fart what is a SAS suburban
