Will L.
That does look nice.
Would be great to see you guys from time to time. I still hope to get out there to the salt flats in the next few years.Thanks Mike. If all goes well for 'Thing 2.5', we might be out your way a few times a year. Son-in-law is trying for a teaching position at Devry near Naperville. Hope springs eternal....
The washers are there because the 'ears' are already distorted from using just the flare nuts in the past. PO overtightened them once upon a time, to the point they spread the ears. I bent them back but the damage was done so I've used the washers to ensure the support stays secure.Looks awesome!
But I must point out, you have a few nuts mixed up on the intake, the thick ones with the floating washer are for retaining the heater hose pipe, the floating washer is so it wont turn and try to tear up and distort the ears on the line support.
Seems backwards to have that thick head on such a light duty task, but I guess the washer is the big deal.
Good Point. I got the inside covered with the stuff from when the carpet was pulled out for cleaning after the heater core let go a couple of years back.if you cover it you will lose the reflective r value
I agree. I've pretty much decided that what's left can be done while it is running and driving. More to the point, no need to let perfection get in the way of good enough for a project that is dragging out much too long for its intended purpose.Good to see you are back in town and back on your truck. Its been far too long since it's been on the road
