JiFaire
Land Mine Finder
I figure if you try hard enough, you can make darn-near anything blow up.  Get any turbo over 100K and inject a little steam and it'll dump when the pressure surge hits.
while we're on the topic of made in china i thought i might post this video. take from it what you will....
Remember Japan, Korea, Mexico, Taiwan, and a host of other trading partners "outsourced" part suppliers were purveyors of of junk but are now desired some even being touted as standard of excellence, which at one time you could not give their stuff away.
As for all this China distractive talk, fact is that you can get some good stuff made in China, particularly with products low on the complexity curve. Turbos are definitely low on that curve. Perfect product to be made in China.
Test to fail done right requires sacrificing a statistically significant # of turbo's run to failure conditions, so it's an expensive process.
So often times us experimenters need to make due with measures like an external wastegate w/ more than adequate bypass capacity trying to ensure venturing into uncharted territory w/ a new combination doesn't overspeed & frag a comp wheel. Also a good idea to have an IC or even a simple sturdy screen/strainer to catch any frag. Nothing's certain to catch everything, but these things do occasionally happen when pushing beyond old limits.
The GM turbo looks like a toy compared.
100% correct GMG ATT is a custom build per Slim's specs, look at pics in replacement turbo thread and you can see the differences between the two; NOT a Mitsubishi part in it, yes he checks them all before going out the door,
out of curiosity why the hesitation to a Mitsubishi turbo on your GM?
Buddy good question but one I don't have an answer to, possibly Slim can answer, I thought about it early on, but forgot about it.
Slim Shady, since you have this good relationship set up, have you looked into producing heads as well? slim shady/Heath/ Turbine Doc designed direct injection heads anone?![]()
