OregonHorseTug
Mike
You are running a stock pcm, right? What TDC number are you running?
TDCO set at -1.85. Set by optical bump, best I can do with this vintage and my equipment.
And since I am not from Portland is the top of the Terwillerger curves a steep hill?
Measuring the distance and elevation on Google maps, I get 3 miles climbing 430 ft. Averages almost 3% with some steep parts at maybe 4%.
What was your injection pulse width at 2900 rpm and those 2700 lb injectors? I would be interested in that, did the truck run smooth.
I'd be interested, too. The ScanGauge won't tell me that (at least that I have been able to figure out). I'm going to have to rig up my OBD-2 on my laptop and make another run with the data logger running. The truck runs smooth although I get an occcasional hickup. After a year of running these it is sounding like I have one going soft. I'm planning on going back to 2300# with marine nozzles when I get around to it. I'm still trying to figure the best injector combo for my horse-puller. I've got my old injectors that I want to build my own pop tester and "fiddle with".
No mileage data yet with a load. I'm hoping for a long trip loaded in the next month so I can see what it does.This is intersting stuff and looking forward to some data since you are running the high pressure injectors. Very Very interesting, another person pressing the envelope, what was fuel mileage or do you know yet?
Mike
