sshewins
Jesus Freak
Yeah, sorry bout that. I assumed 'cross over tube' was referring to the cross over tube, not the silicone turbo boot. LOL.
Here are my results. I believe this to be statistically significant. But, perhaps very conservative of actual improvement because...
1. I've been driving it like a stolen rental since the exhaust went in (gm turbo is way louder than A-Team with KD exhaust, I very much like the ATT). I like the quieter attenuator trap. Now it kind of sounds like a 454 with glass packs, but a little quieter under hard acceleration, maybe.
2. I now tow at faster speeds, so one should be burning at a higher rate now vs. baseline. I got just a slight fueling bump with the fuel mileage chip. The egt's are easily managed and the coolant temp is noticably lower and not a problem except with a 45 mph 90 degree crosswind. I have not cleaned the cooling package in quite a while either.
3. The towing has been typical but I believe the side and cross winds have been horrible this spring and summer here on the planes (or is it plains, lol, too funny).
4. Injectors (technically a nozzle?) and Injection pump may reflect additional improvment for mods, since the baseline started with new injectors. Not sure if or how much the injection pump would affect it. I know one thing, I might buy a set of injectors for the sake of this test, but the injection pump is gonna just ride it out.
Here you go...
Overall Improvements (per signature)
13.88% Reduced Cost per Mile
16.13% Improved MPG
Data Set #3: Added; Kennedy Fuel Economy Chip, A-Team Turbo, DEI Turbo Blanket
8.72% Reduced Cost per Mile (additional improvement over baseline)
17.07 MPG
10.69% MPG Improvement over Baseline (additional)
5 Months
10,646 Miles
$0.178 Cost per Mile at $3.03/gallon
Start End
Truck 316,500 327,146
Engine 83,267 93,913
Inj. Pump 179,882 190,528
Injectors 83,267 93,913
Data Set #2: Added; Kennedy Exhaust, Kennedy Fan Clutch, DSG Cam Phaser Kit
5.16% Reduced Cost per Mile Improvement over Baseline
15.50 MPG
5.44% MPG Improvement over Baseline
13 Months
25,367 Miles
$0.195 Cost per Mile at $3.03/gallon
Start End
Truck 291,133 316,500
Engine 57,900 83,267
Inj. Pump 154,515 179,882
Injectors 57,900 83,267
Data Set #1: Baseline Stock GM
14.70 MPG
29 Months
57,605 Miles
$0.206 Cost per Mile at $3.03/gallon
Start End
Truck 233,528 291,133
Engine 295 57,900
Inj. Pump 96,910 154,515
Injectors 295 57,900
Has anybody come up with a kit to mate the ATT to a Peninsular intake, or is the common method still to raid a Cummins elbow and bend a 90*a pipe? Or am I missing something and this is part of the new ATT intake mod?
In case I have to go the bending route as the only option, why not mount the Cummins 2-1/2” to 3” at the ATT end and then flow 3” all the way to the Peninsular?
Paul, its a sad dog who don't wag it's tail once in a while...
