Ok, so I worked through this entire post (well, mostly, skimmed the physics section :bigeyes: ) and not clear on whether there is a specific ECM (OBDII) tune that optimizes for the ATT. So, for somebody like myself with a stock tune, is there one that will take advantage of the ATT's capabilities or just go with one of the preset packages from KOJO / Heath / Kennedy / etc? It looks like KOJO has a tune (presumably specific for the ATT), but what about the others? Did the conversations with Heath ever go anywhere?
Bill Heath did a couple of great tunes for my ATT. One performance and another for economy. Coincidently, the tunes worked very well when I went back to my GM-5 too (ah the fun of experimentation). The first tune (towing) I had that initially improved my GM-5 from it's OEM tune wasn't sufficient to what the ATT needed. It's a matter of experimentation and communication with the tuner. Fortunately, I was able to make the improvements while traveling through the neighborhood on business.
I feel there is a miscommunication here on what terms mean what. Lag is the time it takes from when you romp on it until the boost comes up. It seems to me some are confusing "lag", with a raised power band. GM chose there turbo to basically optimise power in the cruise area as the 6.5 was never meant to be a powerhouse. It seems from what I have read that the ATT is not very laggy, but it DOES raise up the powerband a few hundred RPM's. I know my LB7 doesn't have much boost below about 2K RPM's, yet I don't feel it is laggy in the slightest. The ATT powered truck I rode in was anything but laggy I thought, but it did have a higher powerband than a stock GM-8 turbo'd truck had. There is NO perfect turbo. They will all have tradeoffs in them. Even VVT's have there weakness's to them. For the cost, and what it does, the ATT is an excellent replacement though I feel, and if I had a 6.5 powered vehicle it would be sporting one.
The ATT on the '95 has 57,000 miles on it.
Who has the best suggestion for a new crossover tube? Where to order? Part numbers? The goods????
The English language is a wonderful tool because it is very flexilble, but for the same reason it can be difficult to communicate and easy for same the text to have several different meanings.
Here are my two "sense"... lol....
Who really cares about turbo lag or even turbo boost pressure response time? "Turbo boost pressure response time" would be the "affirmitive" description if one adhered to Roberts Rules of Order right? I think a more meaningful measure is torque response time. For example, if we cruised down the highway at about 300 or 500 rpm above torque peak speed at full throttle, then go to "no pedel" and coast until things cooled off a bit and the engine speed slowed to torque peak engine speed, then go to wide open throttle... then record the time it takes to reach 80 or 90 percent of peak torque. I know, we don't have a "torque gauge" on the old dash. But, my point is torque response is a more meaningful description of the package don't you think?
I believe the all around performance of my ATT on my '95 with a 4L80E and 3.42 ring gear and pinion is alot of fun. I've improved mileage as advertised, all the while I can't stop driving it harder because it is more fun and sounds alot like a 454 rat. Others have commented on how they like the drive by or launch sound too (take note I have a noise attenuatining cat in addition to the see-thru muffler). Perhaps Kennedy has the things dialed in to give the right amount of initial "launch" fueling, then ramping it up appropriately from there?
I can make a little bit of smoke, but I have really give'er the onion from a cold or slow speed.
Another point I should add... If I'm cruising around town or pulling a trailer... I make sure I shift it down to 3rd to stay out of overdrive and avoid lugging a pretty good load down at 1500 or 1600 rpm.
I bought mine from SS Diesel simply because I was having trouble getting a stainless one anywhere else.
Just to be sure, I was talking about the hose between turbo and upper intake manifold. As supplied with ATT, the orange corrigated hose.
I called "http://www.ssdieselsupply.com" at 716-874-6900, and the fella claimed they have never had anything like that?
Are we talking about a different part, or a different vendor?
